Discussion topic: To re connect my sky
Message posted on 08 Nov 2024 11:36 AM
Hi I am try to re connect my sky
Message posted on 08 Nov 2024 11:45 AM
Re: To re connect my sky
Are/were your services restricted?
Message posted on 08 Nov 2024 11:53 AM
Hi @Issaacch1
If this is to connect your Q box to your Broadband then,
