Discussion topic: To freezing
Message posted on 06 Jan 2025 02:03 PM
To freezing
My tv keeps freezing, this is on adverts, live tv and recordings. I tried changing the plug and it still doesn't work
Message posted on 06 Jan 2025 02:11 PM
Re: To freezing
