Discussion topic: No internet connectivity!
Message posted on 06 Jan 2025 12:32 PM
Hi there!
I have been dealing with a connectivity issue for some time and although the Sky Q settings indicate that I am connected to the internet, all relevant internet connectivity settings are correct, I have the message 'it looks like you are not connected to the internet' and apps/recording/and catchup etc are not available.
I have done all the reset router reset Sky Q box, even had a new box delivered but the problem persists!
Any ideas please?
Kind regards.
Andrew
Message posted on 06 Jan 2025 02:14 PM
Re: No internet connectivity!
@Elf490 wrote:
Hi there!
Any ideas please?
Kind regards.
Andrew
Hi @Elf490
Exactly what happens when you complete the following?
Message posted on 06 Jan 2025 02:38 PM
Hi @oldfella
I am on a 3rd party supplier for broadband (Vodafone) and if I follow the procedure you highlight everything works as expected. Q box connects to router (wireless) and internet IP address is populated, as expected, and green ticks appear indicating I am connected to router and also to internet.
After then selecting the home menu a message appears saying 'it appears you are not connected to the internet' and therefore I have no access to apps or recording or catch up.
I actually followed the process highlighted in the YouTube video below in the hope that specifying the transmission band and providing a dedicated user login it might help!
https://www.youtube.com/watch?v=3kRYp271vSo&t=4s
Kind regards
Andrew
Message posted on 06 Jan 2025 02:47 PM
Would be good to know if this works as I have a similar problem since changing my broadband to Vodafone. My Sky box will connect when I enter the broadband password but loses the connection almost immediately (and I get the message you mention). I saw somewhere else that it could be a firewall issue and that Sky could tell you how to change the settings but I can't get through to a human at Sky to discuss at the moment!
