Discussion topic: Thumbnails not loading
Message posted on 22 Jan 2024 12:50 PM
App or channel thumbnails aren't loading despite having restarted main and Q box as well as router...
Netflix and other streaming working so unlikely to be network connection or speed
HELP please!
Message posted on 22 Jan 2024 01:00 PM
Re: Thumbnails not loading
HELP please!
Hi @johnmason
