Discussion topic: There is a delay on both live and recorded/downloaded programmes. When I press rewind, the picture
This message was authored by Ash196 This message was authored by: Ash196
When rewinding, the screen jumps backwards and forwards as well as freezing.  When I go into a recorded or downloaded programme the audio can still be heard from the live tv, the screen freezes and it then either takes a few minutes to change to the recorded programme, or it just stays frozen.  When watching a recorded or downloaded programme, I'm unable to fast forward or rewind
Re: There is a delay on both live and recorded/downloaded programmes. When I press rewind, the pict
Hi @Ash196
Try a Reset Settings in the main Q box hidden menu.
Ash196
Hi.  I have carried out the reset and I'm now not able to pause live tv due to the service not being available due to a problem with the hard drive.  I can switch channels, but can't see any recordings and all apps have disappeared
This message was authored by PandJ2020 This message was authored by: PandJ2020
Then you are likely to need your box switched out.  See https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Remember to remove your viewing card if box swapped.
I am just another Sky customer and my views are my own
Ash196
Thanks for your help.  Much appreciated
