Discussion topic: There is a delay on both live and recorded/downloaded programmes. When I press rewind, the picture
Message posted on 19 Aug 2024 10:19 AM
When rewinding, the screen jumps backwards and forwards as well as freezing. When I go into a recorded or downloaded programme the audio can still be heard from the live tv, the screen freezes and it then either takes a few minutes to change to the recorded programme, or it just stays frozen. When watching a recorded or downloaded programme, I'm unable to fast forward or rewind
Message posted on 19 Aug 2024 10:25 AM
Re: There is a delay on both live and recorded/downloaded programmes. When I press rewind, the pict
Hi @Ash196
Try a Reset Settings in the main Q box hidden menu.
Message posted on 19 Aug 2024 11:31 AM
Hi. I have carried out the reset and I'm now not able to pause live tv due to the service not being available due to a problem with the hard drive. I can switch channels, but can't see any recordings and all apps have disappeared
Message posted on 19 Aug 2024 11:56 AM
@Ash196 wrote:Hi. I have carried out the reset and I'm now not able to pause live tv due to the service not being available due to a problem with the hard drive. I can switch channels, but can't see any recordings and all apps have disappeared
Then you are likely to need your box switched out. See https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Remember to remove your viewing card if box swapped.
Message posted on 19 Aug 2024 12:50 PM
Thanks for your help. Much appreciated
