Discussion topic: The standby button is stuck on amber
This message was authored by: Alan+Jonrd
The remote is working fine and is responsive but the amber light remains on on the SKY Q box. Followed instruction to resolve it but it's still amber.
Re: The standby button is stuck on amber
Hi @Alan+Jonrd
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
This message was authored by: ozsat
Do you mean the box is working fine with the remote - but just displaying amber instead or green?
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
This message was authored by: Ker19
Re: The standby button is stuck on amber tried to follow instructions but box still on amber
Sky Q box stuck on amber and won't turn on by pressing the button on the box
