Discussion topic: The sky mine box remote control is not working
Message posted on 23 Jun 2023 09:38 PM
Good evening can I get some help with my sky, mini box remote controller, not working it not allowing me to change the channel on the television it is just I can only get it to bring the volume up and down can you please help me to set it up to the Sky mine box please
Message posted on 23 Jun 2023 09:46 PM
Re: The sky mine box remote control is not working
First reboot the Mini.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your Sky Q remote or if this is not working press the standby button on the front right of the mini box (Amber led)
If the remote is still not working then
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
