Discussion topic: The sky box keeps switching off
Message posted on 25 May 2024 05:54 PM
The sky box and internet keeps switching off and resetting itself
Message posted on 25 May 2024 06:13 PM
Re: The sky box keeps switching off
Hi @Cham64
