Discussion topic: The batteries in my sky remote for the main sky Q are not lasting long, do I need to request a new r
This message was authored by: Littlepick
Hi, the batteries in my remote for the main Sky Q box are not lasting long, I have changed them approx 3 times in the last 2 months (they are Duracell batteries, not a cheap brand), & the message has come up on the screen again today to change the batteries in my remote again. Do I need to get a new remote or is it a fault that can be repaired
Re: The batteries in my sky remote for the main sky Q are not lasting long, do I need to request a n
Hi @Littlepick
Remove the batteries and press and check every button to ensure that none are sticking.
Replace the batteries and then
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
