Discussion topic: Technical support
This message was authored by: Nicole103
Technical support
Hi, I need technical assistance as I cannot get a signal, totally fuming I cannot get through to anyone to discuss this issue!.
Re: Technical support
hi @Nicole103
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
https://www.sky.com/help/articles/sky-q-picture-problems
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
@Nicole103
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message follow the advice from @nigea99
It’s worth noting that:
