Discussion topic: Technical support
Message posted on 19 Nov 2024 08:20 PM
Technical support
I have had to remove my tv where my main box is downstairs whilst having new flooring. I temporaily unplugged my sky box.
I have switched my main box back on without the tv but now i can only watch pre recordings on my multiscreen box upstairs.
Do i need to press something on the box to make my multiscreen one work fully or will i have to wait until i can return the tv?
Message posted on 19 Nov 2024 08:26 PM
Re: Technical support
You mini box should work if your main Q box is in standby and connected to your Satellite dish and not connected to a TV @EmilyTay
Message posted on 19 Nov 2024 08:28 PM
@EmilyTay are you getting any error messages on the mini box when tryin g to view live TV
Message posted on 19 Nov 2024 08:33 PM
Are the satellite feeds connected to the main box? (If they were removed)
Message posted on 19 Nov 2024 08:42 PM
yes i re connected them
Message posted on 19 Nov 2024 08:48 PM
Hi @EmilyTay
Try rebooting your Q box again.
Then when the Q box is on with green led
Reboot the mini as above.
