Discussion topic: Sky Q Mini won’t turn on
This message was authored by: Rob8
Our Sky q mini is currently needing a reset every evening despite working fine during the day. Doesn't seem to be losing connection as it is working fine the rest of the time. I have already turned off eco mode so that isn't where carding it. Can't understand what the problem is.
Re: Sky Q Mini won’t turn on
Hi @Rob8
Bear in mind that the Standby mode should be the same on all your Q boxes.
Try completly resetting the mini.
Reboot the mini as above.
Avatar for Rob8
We already have a booster mid way betweeen the main box and the mini.
Hi @Rob8
If you main Q box is successfully connected to your router then you can use the Q booster located between your main Q box and the mini.
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
  1. Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your main Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
  2. After a few minutes, the connected light on the booster should  turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
Then carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
