Discussion topic: Technical support
This message was authored by: PMU1
Technical support
I need to fix / replace my sky card as the box cannot read it .why cannot I get a human to talk to ?
Re: Technical support
@PMU1
What is happening when you call?
Avatar for PMU1
Automated reply telling me that they are sending an SMS with a solution and hanging up
What's the solution given in the text message?
@PMU1
Okay, has this text arrived yet and if so have you carried out what it suggests?
Avatar for PMU1
Done it. It's a re boot using 001 in settings and still it won't recognise the card. It says it's not inserted. I tried an old card and it could read that.  All I want is a new card !
@PMU1
Have you tried refreshing your viewing card by pressing
home > settings > system info > viewing card number > setup > viewing card setup - press select to trigger a callback.
This isn't a callback on your landline or mobile phone, its Sky terminology and it will be done over the internet.
Avatar for PMU1
Yes, it didn't work
