Discussion topic: Technical issue with recordings on sky Q
This message was authored by: Julia1963
My recordings on sky Q  keep stopping with a blue screen saying there is a technical issue with the channel please try later. Sometimes if I fast forward the recording comes back for a minute or 2 but then that's it.
The usual channels are absoutely fine. I can use on demand, itv X, iplayer etc with no problems. The only issue is the recordings.
I have checked and updated software.
I have done the usual power off an switch off at at the wall. Then re start.
Nothing seems to work and it is very very frustrating.
Re: Technical issue with recordings on sky Q
@Julia1963
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Julia1963
I have done the things suggested.
Sounds like a failing hard drive
