Discussion topic: Technical issue - sky box has permanent amber light
Message posted on 11 Nov 2023 01:58 PM
My sky box is fixed with a still amber light. The remote control or pressing buttons on the box can change this.
Message posted on 11 Nov 2023 02:00 PM
Re: Technical issue - sky box has permanent amber light
Sorry - I meant to say pressing buttons on the remote control or the box won't change the constant amber light
Message posted on 11 Nov 2023 02:00 PM - last edited: 11 Nov 2023 02:01 PM
I assume you mean "can't" (edit: ah yes 😀)
Have you held the button with the light in it down for 10 seconds?
Message posted on 11 Nov 2023 02:01 PM
Yes. No change though
Message posted on 11 Nov 2023 02:02 PM
Pulled the power at the wall and waited 10 seconds?
