Discussion topic: Technical issue - sky box has permanent amber light
This message was authored by: StevenPayne
My sky box is fixed with a still amber light. The remote control or pressing buttons on the box can change this.
Avatar for StevenPayne
Level 0 icon
Re: Technical issue - sky box has permanent amber light
Sorry - I meant to say pressing buttons on the remote control or the box won't change the constant amber light
I assume you mean "can't" (edit: ah yes 😀)
Have you held the button with the light in it down for 10 seconds?
Level 0 icon
Yes. No change though
Pulled the power at the wall and waited 10 seconds?
