Discussion topic: Technical fault
This message was authored by: Raider999
Technical fault
Over the past few days I have experienced a blue screen with
'There is a technical fault with this channel. Please try again later.
Across the top.
This happens on various channels and comes and goes.
It has resulted in several recordings failing or only part recording.
Has happened on bbc1, bbc2 itv as well as some sky channels.
Has anyone got any suggestions?j8
Re: Technical fault
Across the top.
Hi @Raider999
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Avatar for Raider999
Level 9 icon
Re: Technical fault
@oldfella
Thanks for the link.
I will work through this tomorrow  when my recordings have completed (hopefully)
I didn't say but I have a 2Tb main box
Level 9 icon
Re: Technical fault
@oldfella   got up this morning and everything was back to normal.
Will follow the process if/when problem returns
Level 9 icon
Re: Technical fault
Been OK all day - currently watching football and
101,103, 401, 402, 404, 405, 406 all ok
104, 105, 106, 107, 403 are not
Not a comprehensive list just a few I have checked.
Checked back and 405, 406 now nor working.
This is getting stupid
