Discussion topic: Technical fault
This message was authored by: ChrisDennis
Technical fault
There is No satellite signal since we got anew rooter but it did work yesterday
Re: Technical fault
@ChrisDennis
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
If it's a technical fault as your thread title suggests try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
