Discussion topic: Technical fault
This message was authored by: Shzza
Technical fault
Hi I have a technical fault message. I have rebooted router, sky q box and mini box and nothing has reset it
Re: Technical fault
@Shzza
Were you trying to watch football and was the error message DUG1?
▪️I AM NOT A SKY EMPLOYEE (even undercover)▪️
Avatar for Shzza
Re: Technical fault
No it was when I put tv on no connection to sky Q and when I rebooted sky Q told me there was a technical fault
Re: Technical fault
@Shzza
In that case try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
