Discussion topic: Technical fault
This message was authored by: Tommy4
Message posted on 07 Aug 2024 07:07 PM
Technical fault
Its saying there is a technical fault with this channel on every channel
Message posted on 07 Aug 2024 07:10 PM
Re: Technical fault
Hi
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Technical fault
@Tommy4 try following the link below
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
