Discussion topic: Technical fault
This message was authored by: Donnarubylena
Message posted on ‎06 Jul 2024 09:43 AM
Technical fault
My tv is showing a technical fault
Find out more
Message posted on ‎06 Jul 2024 10:19 AM
Re: Technical fault
Hi @Donnarubylena Assuming that ou mean Sky Q is showing a Technical Fault and not your actual TV then try following the troubleshooting help.
Find out more
Message posted on ‎06 Jul 2024 10:22 AM
Re: Technical fault
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
