Discussion topic: Technical fault
This message was authored by: Rechman95
Technical fault
I'm still getting technical fault message o my sky box. Can't watch any channels yet
Re: Technical fault
Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Technical fault
Hi @Rechman95
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
