Discussion topic: Technical fault
This message was authored by: MandiGaffney
Technical fault
Hi All, I've been having issues with my second box in the bedroom saying technical fault, It's ok once I turn it off and back on usually but now it won't connect at all, and I am now experiencing issues with the main box, it hasn't recorded any of my programmes, when I try and watch them it says recording failed technical fault, Can anyone advise please? I've tried turning the box off and then back on
Re: Technical fault
Hi @MandiGaffney
You could have a hard drive failure.
Check the following link
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Avatar for MandiGaffney
Re: Technical fault
Thank you for your reply! It turned out it was the storage that was full and just needed deleting
This message was authored by: Taylor2Sky
Re: Technical fault
Hi everyone
I cannot get any channel on my SKYGLASS says  "please wait while your program loads" Then says there is a technical fault.
Then goes
back to all the screen programs to watch. But cannot load.
internet is connected ✔️
