Discussion topic: Technical fault
This message was authored by: Cjrdlj
Message posted on 09 Aug 2023 04:26 PM
Technical fault
Sky not worried. Technical fault showing on all channels
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 09 Aug 2023 04:45 PM
Re: Technical fault
@Cjrdlj Have you tried rebooting your main Q box ie
