1
Discussion topic: Technical fault with no picture
This message was authored by Petechipie This message was authored by: Petechipie
Sky mini box has technical fault , can't get a picture however bottom of screen has picture of channels and you can scroll as normal but it won't show main picture or sound. I have turned off and on 5-6 times including overnight to no avail
This message was authored by oldfella This message was authored by: oldfella Answer
Re: Technical fault with no picture
Hi @Petechipie
Reboot the mini as above.
Hi @Petechipie
