Discussion topic: Technical fault on sky sports code DUG 1 id 3c736e - 30th October 2024
Message posted on 30 Oct 2024 08:16 PM
Re: Error code DUG1
Usual crap service from Sky take your money but do t deliver !!
Re: Error code DUG1
Fuming missed 2 goals already on Newcastle match has anyone got it to work
Re: Error code DUG1
Had the same and discovered that if you don't use UHD then it works. Watch the game on just HD and it works.
Message posted on 30 Oct 2024 08:17 PM
Re: Error code DUG1
Tried that. Still error message
Re: Error code DUG1
Just started working now.
Re: Sky Sports + not working
Mine too
Re: Error code DUG1
- I rebooted the glass and it's on now refreshed mt apps 3 times then rebooted give that a try if your on glass or pucks
Same issue- anyone fixed this?
Re: Error code DUG1
No need to call Sky. Just keep trying it through the box whilst watching through the app.
Message posted on
30 Oct 2024
08:17 PM
- last edited:
30 Oct 2024
10:01 PM
by
Chloe-W22
Re: Error code DUG1
[removed] [removed]
Don't forget that Sky need to uphold their end of the contract and actually provide you with the service your paying them for...
Moderator note: removed inappropriate comment and inciting complaints. As per Community Rules.
What’s the point of community if all have same problem and no one from Sky can be bothered to privid
What's the point of community chat if no one knows answer to error problem and no one from Sky is monitoring to help 😡😡 DUG1 what's the issue?
Message posted on 30 Oct 2024 08:18 PM
Same - annoying
Re: Error code DUG1
I wouldn't worry too much, we're already beating you 2-0😏
Re: Error code DUG1
Still not working. Missed 2 goals.
reset everything. Had enough.
Same this is well annoying
