Discussion topic: Technical fault appearing on screen,
This message was authored by: Nosey+Taviner
Css as my get any channels on the tv, telling me there's a technical fault...
Re: Technical fault appearing on screen,
Hi @Nosey+Taviner Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
