Discussion topic: Technical error
Message posted on 22 Jul 2025 12:26 PM
Technical error
Message says technical error - no access to recordings or able to download/watch catchup /ondemand but can use apps for Netflix, iPlayer etc
able to watch live tv
this has been like this for weeks but says try later
losing the will to live with Sky customer service - or lack of it
Message posted on 22 Jul 2025 05:03 PM
Re: Technical error
@Xzarr Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 23 Jul 2025 02:14 AM
Re: Technical error
Yes numerous times same message try later
will not download recordings or play on demand or catchup as cannot download
yet all other apps working
