Discussion topic: Technical error on mini box
Message posted on 30 May 2025 08:26 PM
We have this message on mini box but main Q is working fine
Message posted on 30 May 2025 10:17 PM
							Re: Technical error on mini box
Hi @NGALL78
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 30 May 2025 10:27 PM
That has worked thank you so much
