Discussion topic: Technical and hard drive issue
Message posted on 15 Sep 2024 12:10 PM
Please can I just talk to someone
message on screen saying technical issue and problem with hard drive and no downloads available
Message posted on 15 Sep 2024 12:16 PM
Re: Technical and hard drive issue
Hi @ColletteWB
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
