Discussion topic: Technical Fault
This message was authored by: summertime34
Technical Fault
No TV SIGNAL. Error saying technical fault
Re: Technical Fault
This has nothing to do with Sky Go 😞
Which Sky System do you have?
Sky Plus (Sky Plus Forum)
Sky Q (Sky Q Forum)
Sky Stream (Sky Stream Forum)
Sky Glass (Sky Glass & Live Forum)
Re: Technical Fault
@summertime34
I take it this is a Sky Q issue as per a previous post you made, so I have moved your post to the Sky Q forum.
Re: Technical Fault
Hi @summertime34
If it isSky Q
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
