Discussion topic: Technical Fault
This message was authored by: JamesW2
Technical Fault
I'm having technical faults with my sky channels
Re: Technical Fault
Hi @JamesW2
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Avatar for JamesW2
Level 0 icon
Re: Technical Fault
I'm having technical faults with my Sky Channels can anyone please help
Re: Technical Fault
No need to post twice @JamesW2
Did you read my post????
