This discussion topic has been answered Discussion topic: Tec fault
Message posted on 25 Mar 2024 01:12 PM
Hi got a black screen with technical fault written on it.
Message posted on 25 Mar 2024 01:37 PM - last edited: 25 Mar 2024 01:38 PM
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
If that doesn't help take a look at this link
Message posted on 25 Mar 2024 04:18 PM
Re: Tec fault
All OK now thanks.
