This discussion topic has been answered Discussion topic: When I first power on my new LG smart TV with my Sky Q remote it displays the LG channel page.
Message posted on 30 Oct 2023 07:16 PM
When I first power on my new LG smart TV with my Sky Q remote it displays the LG channel page. I have to power off again the power on the get it to display the Sky Q home page.
Message posted on 03 Jan 2024 06:31 AM
Can't copy the link but basically it was to go into settings on LG tv.... (cog button)
all settings
general
system
additional settings
home settings
and then uncheck the 3 boxes that say home auto launch, home promotion and content recommendations.
Hope this helps
Message posted on 30 Oct 2023 07:24 PM - last edited: 30 Oct 2023 07:37 PM
Re: When I first power on my new LG smart TV with my Sky Q remote it displays the LG channel page.
Hi @alanrotty
If you have HDMI Cec control On in both Q box and TV then when you turn on the Q box then the TV should come on via Cec control. (Short press on the Q remote Standby button)
However when switching Off both TV and Q box need to be put int standby independently. (Q box with Short press - LG TV with long press if correctly paired to the TV)
In the Q box HDMI control is in Home - Settings - Setup - Audio visual.
According to Google Lg is as follows
- From [General], select [Devices].
- Select [HDMI Settings].
- Enable or turn on the [Simplink (HDMI-CEC)].
- ➔ Enable [Auto Power] in [2020 webOS 5.0] ...
- From [Connection], select [Device Connection Settings].
- From [Device Connection Settings], set [Simplink (HDMI-CEC)] to On.
Message posted on 28 Dec 2023 01:52 PM
I am having the same issue, I have change my sky Q box (after having issues) when I turn on the TV. The LG screen appears. I was able to press the home button previously and both the TV and sky Q box with both power on or I could turn on the TV and sky Q box individually. I have followed the above instructions, but still nothing and I am having to use the LG Magic remote to select sky QHDMI
Message posted on 31 Dec 2023 09:30 AM
hi, did you manage to find a solution to this please?
Message posted on 31 Dec 2023 12:19 PM
Try:
Go to
then set the option to Off.
Message posted on 02 Jan 2024 10:49 AM
@cuke I cannot see these commands on sky Q box?
Message posted on 02 Jan 2024 11:28 AM
Message posted on 02 Jan 2024 11:58 AM
@cuke thank you, but it still doesn't work 🤔
Message posted on 02 Jan 2024 05:38 PM
Message posted on 02 Jan 2024 06:56 PM
Mine is sorted now, I googled the problem and found a video on YouTube that talked me through some settings to try.
thanks for the help everyone
Message posted on 03 Jan 2024 05:02 AM
@kanny wrote:Mine is sorted now, I googled the problem and found a video on YouTube that talked me through some settings to try.
And can you share which ones worked as others seem to have the same issue?
all settings
general
system
additional settings
home settings
Hope this helps
Message posted on 03 Jan 2024 05:39 PM
Unfortunately it's still doesn't work! So fustrating....the model is OLED55B9PLA if anyone has any suggestions it will be appreciated.
Message posted on 03 Jan 2024 06:02 PM
All sorted now. Don't set the LG TV to turn off in power save mode
Message posted on 04 Jan 2024 09:08 PM
@kanny wrote:Can't copy the link but basically it was to go into settings on LG tv.... (cog button)
all settings
general
system
additional settings
home settings
Hope this helps
Yes I've just discovered that apparently LG released a firmware update before Christmas that forced a default home page and, as you stated going to All settings> General settings>Additional settings>Home settings and turn off Home Auto Launch, or anything else, resolves it.
