Discussion topic: TV
Message posted on 01 Mar 2024 09:20 PM
TV
TV not working my TV is not connected to WiFi
Message posted on 01 Mar 2024 09:52 PM
Re: TV
Hi @Kkakaksk
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Message posted on 02 Mar 2024 09:08 AM - last edited: 02 Mar 2024 09:08 AM
Re: TV
TV or Sky Q box is not connected to the internet?
