Discussion topic: TV
Message posted on 10 Oct 2023 09:03 AM
TV
We have poor sky connections on mobile and television
Message posted on 10 Oct 2023 09:09 AM
Re: TV
@Anonymous You'll need to provide a bit more detail for the forum to help.
What is the exact issue, any error messages on your TV?
Message posted on 10 Oct 2023 09:23 AM
Re: TV
No connection have to constantly push the button on the sky box
which also means we have no mobile signal
Message posted on 10 Oct 2023 09:24 AM
Re: TV
Hence delay in responding as have on and off mobile connectivity
Message posted on 10 Oct 2023 09:33 AM
Re: TV
@Anonymous I'm confused as to how a Sky Q box can affect your mobile signal?
Do you mean your box is having issues connecting to your broadband hub? Can you be nmore specifi what box is affectig what box. Have you tried all the steps here?
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-connectivity
Message posted on 10 Oct 2023 10:13 AM
Re: TV
Maybe the phone is trying to use the Q as a wifi hotspot
not sure why it wouldn't drop back to direct connection to the router or 4G though.
Message posted on 10 Oct 2023 10:33 AM
Re: TV
It's hit and miss not all the time
Message posted on 10 Oct 2023 10:42 AM
Re: TV
@Anonymous wrote:It's hit and miss not all the time
Are you on sky broadband?
I think you can turn off the Q hotspot feature if you want your phone to just connect direct to your router which might be more stable.
Message posted on 10 Oct 2023 12:32 PM
Re: TV
Don't think we have Q whatever that is...
Message posted on 10 Oct 2023 12:33 PM
Re: TV
I am up the Shropshire hills getting better reception than the house
Message posted on 10 Oct 2023 01:16 PM
Re: TV
@Anonymous wrote:Don't think we have Q whatever that is...
Hi @Anonymous Perhaps the confusion is you are posting on the Sky Q community?
Message posted on 10 Oct 2023 02:19 PM - last edited: 10 Oct 2023 02:19 PM
Re: TV
Well, yes: a cellular data connection with line of sight to a mast is quite likely to be 'better' than poor local WiFi within a building.
Message posted on 10 Oct 2023 02:25 PM
Re: TV
@Anonymous So which Sky TV service do you have? You will have either Sky+HD, Sky Q or Sky stream/Sky Glass.
As the description "Sky Box" covers all of the above and the Sky broadband Hub.
