Discussion topic: Sky box doesn’t turn on
This message was authored by: Vicky+windsor
My sky box was down now it won't come on I have re booted this
Re: Sky box doesn’t turn on
Hi @Vicky+windsor
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
