Discussion topic: TV
This message was authored by: Old
TV
Both TV's have a technical fault, the screen comes up as normal but no Chanel's are wiry including apps & recorded programs
Re: TV
Hi @Old
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
