Discussion topic: TV sky codes for TV
Message posted on 19 Sep 2023 11:38 AM
TV sky codes for TV
Hi,
Just trying to get my tv's back working with the sky q and sky q mini, just moved house and they were all working fine before the move so it is strange both of them are not working.
The samsung tv model numbers are UE42F5000AK (main Sky Q box and UE32T5300AK Sky Q mini
I have tried all of sky's default codes and the tv setup wizard without success but they both was working fine with them.
Any suggestions would be helpful, Thanks in advance.
Message posted on 19 Sep 2023 11:41 AM
Re: TV sky codes for TV
@Jamie2k2 wrote:Hi,
I presume you did the home move with Sky? @Jamie2k2
Message posted on 19 Sep 2023 11:42 AM
Yes we did.
Message posted on 19 Sep 2023 11:50 AM
@Jamie2k2 wrote:Yes we did.
What codes are you looking for? The boxes don't work via a code. They get connected to your satellite dish and connect to your tv. You just then need to connect to your router
Message posted on 19 Sep 2023 12:37 PM
When setting the boxes up it ask's you if you want to set up your tv to use the sky remote to control the volume and the power on/off etc.... It says to pres and hold buttons 1 & 3 together followed by the code provided on the screen (4 digit code). The remotes work fine with the sky q boxes.
Message posted on 19 Sep 2023 12:42 PM
Hi @Jamie2k2
Bluetooth Sky Q remotes (with microphone for voice control) do no use codes they use TV brand and model. The early Infrared remotes used codes.
First try rebooting your main Q box. And then repeat procedure with the mini.
ThenTry completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 19 Sep 2023 01:00 PM
I am so sorry im not very good with tech,
I have followed your steps for the Sky voice control and works fine now (thank you). The Mini Q remote is working with the box but the remote is different. to the main box and is not conneting to control the tv.
But i did do the start up wizard and also manually trying to find the model number but unable to.
Message posted on 19 Sep 2023 01:59 PM
any other suggestions please?
Message posted on 19 Sep 2023 03:06 PM
Hi @Jamie2k2
Looks like your mini remote is the original infrared version (without the microphone button and no voice control).
Therefore it will need the 4 digit code for the TV.
Carry out the same reset procedure again on the mini.
Go to Home - Settings - Setup - Remote control. Choose the Sky Q remote.
In Remote control setup
Use find it for me and then enter brand (Samsung)
For model Use find it for me.
When you are asked to press 1 & 3 together make sure the red led above the Sky logo on the remote flashes twice and then Enter the code.
When you try to change volume make sure that you are pointing the remote at the TV.
For other commands (such as selecting Yes - No - Finish) you need to point the remote at the mini box.
For all normal mini commands it needs pointing at the mini.
For TV On/Off (long press) or mute or volume you need to point the remote at the TV Set.
Message posted on 19 Sep 2023 03:17 PM
Thank you for the deailed advice, i have completed this step and the box has 8 codes but none of them worked at all. This is what i am looking for the acual sky remote code for the tv. It has worked before but i do not remeber the code i used.
Message posted on 19 Sep 2023 03:31 PM
Hi @Jamie2k2
Did you make sure that the remote LED flashed twice before you entered each code?
Message posted on 19 Sep 2023 03:37 PM
Yes i did every time and made sure i waited about 20/0 seconds before trying another one if the volume button did not work.
Message posted on 19 Sep 2023 03:38 PM
Sorry 20/30 Seconds
Message posted on 19 Sep 2023 04:00 PM
Hi @Jamie2k2
Just to make sure.
Did you press 1 & 3 before trying each code? (Don't know you need to wait so long before trying the next code)
If So all I can suggest is that you try the model UE32.... and try a few of the models that come up
