Discussion topic: TV remote isn’t working
Message posted on 06 Oct 2023 12:13 PM
TV remote doesn't work despite changing the batteries
Message posted on 06 Oct 2023 12:27 PM
Re: TV remote isn’t working
Is it still paired with your box?
If your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It might be quicker to purchase a new one from a retailer / main supermarket. If you do that as well you’ll always have a spare.
Message posted on 06 Oct 2023 12:36 PM
Hi @Sarah4609
Try completly resetting your Bluetooth remote.
