Discussion topic: Sky box not working, switched off still not working left off overnight still not working
Message posted on 06 Oct 2023 11:23 AM
Sky box not working, unplugged switched on not working left off over night still not working trued again several times still not working
Message posted on 06 Oct 2023 11:25 AM
Re: Sky box not working, switched off still not working left off overnight still not working
Hi @Dominique14
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 06 Oct 2023 11:29 AM
Try the recovery procedure on step 3 as desribed in this Sky help article;
Message posted on 06 Oct 2023 11:34 AM
Amber led won't change but thank you x
Message posted on 06 Oct 2023 11:37 AM
Hi @Dominique14
Did you try pressing the amber led on the Q box?
Message posted on 06 Oct 2023 12:51 PM
I did press Amber led and it wouldn't change.
Have tried reboot and it's stuck trying 1 of 2 so I've just turned it all off. As need to be elsewhere so will try again later.
Thank you for your help
