Discussion topic: TV picture and sound out of sync.
Message posted on 27 Dec 2024 07:00 PM
Message posted on 27 Dec 2024 07:36 PM
Re: TV picture and sound out of sync.
Is this Sky Q related, as you had posted this in the Sky Go forum on here ?
Message posted on 27 Dec 2024 07:37 PM
@Antonyandelaine wrote:
The TV picture and sound are out of sync. Turned box off/on is the okay for a few hours and then is out of sync again.
Message posted on 01 Jan 2025 01:58 PM
@Antonyandelaine check out discussion...... Discussion topic: Lip Sync issues - Sky Stream
