Discussion topic: TV not UHD
Message posted on 28 Jun 2025 08:57 PM
TV not UHD
Our TV upstairs won't support UHD so we can't watch recorded shows. Is there a way to record in standard HD?
Message posted on 28 Jun 2025 09:06 PM - last edited: 28 Jun 2025 09:26 PM
Re: TV not UHD
Almost all broadcast television on mainstream channels is HD: there's very little UHD being transmitted. For on-demand content you'd need to select the HD rather than UHD download.
Unfortunately a main Q box cannot turn a UHD recording into HD for playback from a Q Mini.
Message posted on 28 Jun 2025 09:10 PM
Re: TV not UHD
Message posted on 28 Jun 2025 09:16 PM - last edited: 28 Jun 2025 09:19 PM
Re: TV not UHD
SD, HD, UHD – whatever your definition of choice, you can download in it if you have the right TV equipment and subscription.
To change your download preferences, you need to complete this on the main Sky Q box, not a Sky Q mini box:
Press Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then On Demand default download format, and choose SD, HD or UHD.
If your default download format is unavailable, it’ll download in the next available format. For example, If HD is unavailable, the show will download in SD.
https://www.sky.com/help/articles/downloading-on-sky-q
