Discussion topic: TV cutting out when watching recording
Message posted on 27 Mar 2023 10:37 AM
When watching a recording on sky Q the TV goes blank, switches off and after a few minutes restarts. This does not happen when watching TV normally - only when watching a recorded programme. Any ideas?
Message posted on 27 Mar 2023 10:40 AM
Re: TV cutting out when watching recording
Hi @01467Jim
Message posted on 27 Mar 2023 11:18 AM
Thank you for the very rapid response.. Box reste so hoping issue resolved. Thanks again.
Message posted on 27 Mar 2023 11:59 AM
