8
This discussion topic has been answered Discussion topic: no signal on sky q box
This message was authored by: cadgwith-cove2
Had a problem with old sky Q box with no signal, had an engineer replace it after 4 days the old problem came back no signal?
Any suggestions?
This message was authored by: Chodley Answer
Re: no signal on sky q box
But what I mean is - is the TV definitely on that input?
and is the light on the sky box changing ok from orange to green when you turn it on?
I guess it's possible another box has died but quite a coincidence.
No Signal or No Satellite Signal?
Avatar for cadgwith-cove2
No signal comes up on TV
And you've triple checked it's on the right HDMI input?
replaced the cable?
yes replaced HDMI & power cable and still the same issue
And you're 100% certain the right HDMI input, it's not auto-switching to something else?
Its in HDMI 2  where the engineer left it
@cadgwith-cove2
No signal is normally a message from your TV. No satellite signal comes from your Sky box.
