Discussion topic: TV buffering whilst watching
Message posted on ‎21 Dec 2024 01:24 PM
The TV screen seems to lose the signal and we are unable to watch or hear until the signal is restored. This only last a short time but is rather annoying. Also after watching for a while the Sky Q box freezes and we have to switch off and reset. This happens too often and obviously affects the auxiliary box.
Message posted on ‎21 Dec 2024 01:54 PM
Re: TV buffering whilst watching
Hi @Ezmoney
