Discussion topic: sky mini box not responding to remote, tried the reboot options and remote connectivity option.
This message was authored by SteveJ62 This message was authored by: SteveJ62
Sky mini box wont respond to remote, tried rebooting main box and mini box, that didnt work. Tried resetting remote, that didnt work. Screen stuck on "Accessibility on Sky Q" screen, remote wont work., cant get off this screen
This message was authored by Laing1 This message was authored by: Laing1
Re: sky mini box not responding to remote, tried the reboot options and remote connectivity option.
@SteveJ62 try the following...
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
This message was authored by Paul30575 This message was authored by: Paul30575
Yes it's stuck
