3
This discussion topic has been answered Discussion topic: TV antenna
This message was authored by: Vijendra1
TV antenna
I have cancelled subscription & returning Sky Q box & accessories
Does SKY  get rid of TV antenna since  it was installed by SKY when bought subscription.
This message was authored by: stereohaven Answer
Re: TV antenna
No, ownership of the dish and cabling passes to you at install, so it is your responsibility to remove it if that is what you want to do.
Alternatively, if you wanted to use it for another device you can.
Re: TV antenna
Re: TV antenna
hi @Vijendra1
No, SKY do not remove dishes.
Ownership passes to you - if you want it removing you can arrange for this yourself by any tradesman or DIYer (or yourself) - it does not need to be a Satellite specialist
Re: TV antenna
Hi @Vijendra1   You could use it with a 4K Freesat box.
