Discussion topic: TV and broadband issues
Message posted on 27 Nov 2023 11:37 AM
Message posted on 27 Nov 2023 11:46 AM
Re: TV and broadband issues
@Bigman69 wrote:TV and broadband issues
You'll need to be just a tad more specific...
Message posted on 27 Nov 2023 11:58 AM
I'm meant to get 600 minimum 400 and don't believe that's happening.......TV pixels...... programmes buffering
Message posted on 27 Nov 2023 12:02 PM
@Bigman69 Please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Message posted on 27 Nov 2023 12:44 PM
@Bigman69 wrote:I'm meant to get 600 minimum 400 and don't believe that's happening.......TV pixels...... programmes buffering
Broadband speeds are measured to your router. You may not get the full bandwidth depending on many factors.
If the TV is pixelating then it sounds like an issue with your dish.
Message posted on 27 Nov 2023 01:11 PM
Ok many thanks 👍
Message posted on 27 Nov 2023 04:33 PM - last edited: 27 Nov 2023 04:34 PM
Stand next to your router with a phone* (or use a wired PC) and go to speedtest.net to find out what real broadband speed you are getting.
* wifi sometimes can't get as high as 600Mb so it's best to use a cabled connection for this test.
Message posted on 27 Nov 2023 05:01 PM
I did .....60/70/80
Message posted on 27 Nov 2023 06:00 PM
@Bigman69 wrote:I did .....60/70/80
On a fibre to the house connection?
Message posted on 27 Nov 2023 06:46 PM
Re did it there........still meant to b 600
Message posted on 28 Nov 2023 08:06 AM - last edited: 28 Nov 2023 08:06 AM
"Poor signal" suggests you were not standing next to the router so were bottlenecked by the wifi connection, not the internet connection.
